That really looks good. More pics please.![]()
The cage looks GREAT! I can't wait to get home so I can see it on something bigger than my phone.
x2 SIR!!!![]()
That looks killer dude.
One thing though, if you solid mounted the cage, why are you running rubber body mounts still? Or did I look at it wrong?
Thanks!
Thank you
I'm not really sure what you are asking. I never have touched my body mounts, nor do I really care about that. I was just trying to tie my cage into the frame for strength all around. Don't really care if the body mounts are in good shape or anything since this is a trail only rig, as long as it's strong is all I really care![]()
Your body mounts are what holds the body up. Most of them are in locations that has some sort of ribbing on the body for more support. Now those are doing nothing and your floor flanges are basically holding the body on. Not saying its really a bad thing.... But I would bet you will see cracking of the floor around the cage plates.
IMO it would be better to replace the body mounts with a solid puck if you are doing solid frame tie ins.
And if it does, I will just weld it up, no big deal. And considering that I didn't lifted the truck up off the body mounts to build the cage, the body mounts will still see at least some function, even if it's small. So I doubt I will see too much of a problem. And this is just a trail rig, no plans for high speed anything so I think it will be finelike the design![]()
Considering how many holes are already in my floor, I don't think I will care too much about some cracking.And if it does, I will just weld it up, no big deal. And considering that I didn't lifted the truck up off the body mounts to build the cage, the body mounts will still see at least some function, even if it's small. So I doubt I will see too much of a problem. And this is just a trail rig, no plans for high speed anything so I think it will be fine
I love the cage and THANK YOU for posting all the pics from different angles. Your design is very similar to what I want to do.
Would you call it finished or do you plan to add more? If so, where?
One more pic request; can you take a side shot with the rear seat unfolded? I'm trying to see where the upper C pillar bend is (needs to be) in relation to rear passengers.
Yah like I'm sure you will be fine. Just thought I'd ask.
Turned out really awesome looking. I wish I had access to a 2" die for when I do mine. Looks so much better than 1.75.
