My new build...the "me too" short Crew Cab ~UPDATE~ not selling it
Here are some updates.
Made a steering shaft to clear the coilover.
Because I mounted them angled in at the top the d/s coilover is directly in the path of the OEM shaft.
Used 2 XJ shafts and a 3/4 heim joint to snake the shaft around the coilover.
Got the Dana 60 built. Putting the axles together was a breeze. CTMs are by far the easiest Ujoint Ive ever installed, no little needles to fall and jam things up.
Had to grind away part of the housing to install the OX.
Looks awesome Vinny :waytogo:
You still trying to make it to Rausch in June ?
Im trying...
But its not looking good. Still have a TON of work to do. Wiring, plumbing, cooling system, fuel system, body work, interior, driveshafts, etc. etc.
Tossed the fenders on and got it sitting on all fours.
Pretty happy with the ride height.
Got the hydro assist ram mounted and lines run.
Also got the rear straps and bumps mounted.
Ran brake lines and got the system bled.
Never seen this one till today either. Should look good with a tiny short box on it.
Martin
Looks awesome Vinny :waytogo: can't wait to see it person one day :D
Thanks guys.
Im making progress, but still have a ways to go.
Just checked out the Rausch thread and cant wait to make it out there.
Subscribed!
Very cool build Vinny! I am glad you are well on your way to create another great truck! I may have drive down to see it in person!
Been busy re wiring the whole truck.
Made a fuse/relay box for the 6.0
The underdash harness was pretty hacked by previous owners, so I ordered a new wire harness kit from American Autowire.
