Don't matter if you can't see the pics, your problem is different than mine was. Should have read a little better.
Sorry I didn't notice the above reply's when I posted. I have the bolts to the springs in real loose so there is alot of side to side movement. So what your saying is unbolt the axles then ubolt them in then install the front spring bolt? That would work if I could manipulate the axle enough.
Thanks,
Jason
So I should disconnect one of the eye bolts and then install the ubolts? How am I going to stretch the spring enough for it to bolt up? To be honest that sounds alot harder than just pulling the axle, I'm having trouble visualizing how I would pull this off.
Jason
Good luck
You have to squeeze hard , and it also should be noted that the springplates that originally had the swaybar mount has different hole spacing on one side of the plates for some reason , at least on the ones I own![]()
. I'll get the front end finished up in a minute after I get off the computer. I wonder what is going to stop me tomorrow when I start on the rear?
