So I'm beginning to wonder if this problem is more of an issue with the trans than the motor. On flat ground it seems to shift normally although I'd like it to hold the gears a tad bit longer before downshifting. The problem seems to come on steeper grades. When you get deeper into the pedal where maybe a healthy trans would upshift this thing just kinda wallows. I came across an old posting of Can Can's where he mentioned a shop fiddling with his TPS and the TV cable and I'm wondering if I should look into that.
I found the TV bracket but I haven't attempted to adjust it yet. If it's out of whack could that explain the drive-ability issues I've been experiencing?
I checked the IP advance lever that bradshawtech mentioned and everything appears to be functioning correctly.
I bought Can Can's diesel pick-up three years ago. That pick-up still has issues with not downshifting when it should on medium/shorter grades. OD down to 3rd is the usual culprit, and it's where I now regularly just pull the shifter down one notch for particular grades I drive almost daily. I may have to double check the TV set-up...
Rene
) I've got a fully rebuilt 700R4/208. It was amazing that this thing still had all it's gears. The band was dead, some of the clutches were almost down to metal and the rear spider assembly was all chomped up. The leak was actually coming from a cracked weld on the (aftermarket) torque converter. The 208 was also leaking between the case halves so I got that sealed up too.
, but this is the night and day difference I was hoping to achieve.
