New guy here with a 78 gmc jimmy !
This is it, it's a 10 footer originally black with red plaid interior similar to yours. 350/350/203
I think it's had a part time kit put in but I drove it for about 5 miles before the trans burned up. It needs a lot but it's actually almost rust free, two spots on the front floors that have been patched and one in an inner gender well due to a battery. The frame looks almost new however . New 6" spring lift and shocks, good interco tires etc. previous owner was a dumbass kid so it's got some questionable mods
So will adding just the locking hubs make it a 2wd truck? Sorry if I'm not following
pics of your blazer? I wish i had one without the 203 lol just couldn't pass it up for the price !
That 203 is not going to hurt you. Put a set of locking hubs and drive it. You will only be using the rear axle. The front drive shaft and front axles will still be turning but not connected to the front wheels because of the lockouts.
You can always put a part time kit in the 203 if you want, I never did and don't care. You also must engage 4 high every 100 miles or so to properly lube the bearings in the t case.
Gas mileage and wear and tear, whatever, get a Prius.
205 swap will require different length driveshafts also. Then you can swap a 14 bolt and a Dana 60 with 8 lug wheels.
The 205 has its advantages of be able to go in and out of 4x4 from the cab if you keep the hubs locked. 203 can't without a part time kit installed.
Seriously if your just going to drive it don't get caught up in all that IMHO.
If your going to rock crawl well that's different.
Just have fun with it.
No unfortunately it's been redone in black Naugahyde but it looks good. The PO painted the door panels in Orange bedliner though. Ugh.
It's not a hard thing to swap out if you have a strong disliking for it. If you hafta take it down and tear it apart for a part-time conversion, it's probably less work to just throw a functioning 205 in there. Assuming this truck is too old to have the newer 6-bolt transfer case pattern (which would give more options yet).
To answer the first question, you'll only have power to the back wheels when the hubs are unlocked, but you will always be spinning the front drivetrain (driveshaft, gears, axle shafts, etc). It will function like 2WD, but you will burn extra fuel and put extra wear on the gears. Whereas a part-time system will disengage the front drivetrain entirely.
You also will not be able to go anywhere when the front hubs are unlocked unless the 203 is locked. Otherwise, it acts like an open differential and will just spin the front shafts (which aren't hooked up to anything).
So hubs are a step in the right direction, but they only get you half-way there.
Ok, thank you very much for cleaning that up! How long and how challenging is just a hub swap?
It's purely a cruising dirt roads and the occasional mud hole type of vehicle ! Might do the 203 part time swap one day ! Thank you very much for the insight ! This whole full time 4wd thing and driving on pavement is gonna take some getting use to !
is a 205 swap hard ? How much would the swap cost, just a ball park figure ?
Driveshafts are going to be different lengths so both replaced or resized.
Transfer case with adapter for your transmission and shifter setup.
Basically bolt in deal. Tcase crossmember will be moved fwd. Holes should be in the frame.
Donor truck with all the parts would be the easiest route.
Depends on what parts go for in your area and what's available.
Very straight forward. You could probably swap both lockouts in 1/2 an hour.
I have pictures of the process in my thread if you want to see what things look like (both the drive flanges that you have and the lockouts that the newer trucks have).
https://ck5.com/forums/threads/the-great-smaug-expedition-build.313869/page-2#post-3438676
Is the only way to view that with a premium membership? That thread looks like exactly what i need to help me do this !!!
Thanks for the advice !! what model year do i need to get for it to have everything i need???
Wasn't able to get too much done because i was doing some land maintenance to prepare for deer season ! I did try to get the crankcase filter thing on that i linked earlier that i got off amazon, but the end of it is too big for crank case hole, so i might try to rig something up with some rubber hose !
if that does not work i might try to go with this ?
http://www.rockauto.com/en/moreinfo.php?pk=91722&cc=1156317&jsn=389
The jimmy did start making a kind of high pitched whine type noise coming from what seemed like the upper most passenger side of the engine compartment? didn't really get to check it out as i was fixing to leave? Belts maybe ? i do have a video !
Not sure, but I have found this membership is well worth the funds. The amount of information conveyed in a good picture is worth many hours of blindly trying to grope your way through a problem. If you're doing much work, and your time is worth anything to you, the $25 here will more than pay for itself in the form of pictures. Lots of guys on here have done that NP205 swap you're eyeing (I haven't, so I'm not going to answer your question), their pictures would help you out a lot. That's my opinion, worth what you paid for it. :wink1:
Auto zone carries a "Spectre" brand 3/4" diameter push in breather.
Does the squeal change when you change the speed of the heater fan?
I couldn't find a single specter 3/4 filter !!! :(
I flipped the heater and fan switches back and forth and that did not seem to help any, We did take the ac compressor off if that makes a difference?
Any push in breather would work. You need to make friends with the oldest parts guy you can find.
I normally go to the Napa in town where they know by name lol, they have a husband and wife who work there who helped me the first time i asked them about the crankcase filter. The older guy who hangs out and works there wasn't there on that day !
Said i need a premium membership, what does the pic say ?
Got the crankcase filter in yall !!!
quick question for yall... whenever I'm driving it and i take a turn moving at say 5-10 mph it seems like i hear a noise and then it starts pulling to the left noticeably ? after a while it goes away
Loose steering component? There are a number of things that can cause noises. What type of noise do you get?
My guess was something to do with the full time 4wd, steering is a good guess !! I'm not 100% sure i will check when i can ! Any way i can diagnose it as steering ? Like things to look at?
A front axle u-joint that has rusted up needle bearings or seizes up can cause a hard pull to one side for a few seconds,then it can free up,and the truck wants to dart in the other direction suddenly..it can be scary and dangerous,especially on narrow streets !..
It is not easy to diagnose,if all the tie rod ends and ball joints check out OK,this is a possibility..you cant really tell by looking at them or spinning a tire with it jacked up,if thats the cause..
Only when you pull the joint apart and find no grease and its all rusted up,or worn out, will you know that might be the cause..unless they are completely shot,then you'll see the lack of needle bearings and feel slop between the "cross" and the bearing cups..
