New TOY (pun intended) !!
Maybe the sr5's had switches there.
I am sticking in a tpi 350 in my 87 4runner next time I put in a new engine.I was going to do it this time but didn't have the time.
ones for the power antenna and I forget what the right one is.
Okay, another question. When do I use the clutch button? The P.O. said they use it whenever it wont start, and the manual says only in bad situations...
no luck with that 86 FSM yet either...
Right side is for the reasonably rare digital clock.
Left side is where I've seen the power tailgate window switch in 4runner's. Cargo light switch on both of my trucks is on the other side of the steering column down low.
Alright those are what I forgot about. Thanks
Looked through the little booklet the truck came with. Is this engine (22re) also known as the 22re-c? What does that mean? Thats what the booklet calls it...
84gmcjimmy said:
Whats the difference between the single chain and dual chain kit? Whats better?
Stock comes with single, right?
anyone answer it?
20R's are dual row timing chains. I think some of the early 22R's are as well, but I can't say so for sure. I have both a tall deck and a short deck 22R (early and late versions respectively) and both are single row. Reportedly the double row lasts longer and doesn't stretch as fast.
The Neutral Safety override switch is so that you can start in gear w/o having to push the clutch pedal. Use it when off road in spots where you don't want to roll backwards.
84gmcjimmy said:
so if I can afford it, the dual row would be better since it lasts longer like you siad?
Thanks
i may be jumping in late, but the dual row chain is not needed. the real problem is the plastic timing chain guides. upgrade to steel guides and you'll be just fine.
by the way the timing chain in my old 91 made it 145k before it was replaced, not because anything went wrong, but because it blew a head gasket, and i thought it was time.
the second chain is prob still on the truck, had 333k on it when i sold it. upgraded chain guides is the way to go.
ryan
Correct,the stock guides are plastic and wear fairley fast,good for plastic but...I would get the metal guides also,much stronger.
Those guides come in the LC Engrg kits.
FWIW the cam drive stuff has an approximate life of 125k miles and one place I know of says 50k max. I know there are those that have gone longer. Depends on how you drive. Compression braking works those parts hard.
The downside to limping one along is that once the guides are broken (a 'when', not an 'if' w/ the plastic guides) the chain next hits the timing cover. Right where the coolant from the H2O pump passes thru to the block. when it eventually grinds thru you'll have a much bigger problem.
So the LCengineering kit would be best since the guides are not plastic? And I only need single row?
Sounds good. It's not driving right now, the ford stole it's lisence until we sell the ford. So once I get it insured, I will hopefulyl get some money to buy the kit.
Thanks. Anything else should be repaired?
hey hey I wan't this!
sr5
Is this one okay?
http://www.toyotacatalog.net/m1webgear/ProductDetails.aspx?PartID=1015033&PartRevisionID=
Timing Chain - 22R Single Timing Chain Kit (85-95)
Heavy Duty Timing Chain Kits are available for double or single applications. These heavy duty chain kits are the strongest kits on the market. Manufactured in Japan, these kits are OEM quality at a fraction of the price. Beware of imitations.
Kit Includes:
* Heavy Duty Chain
* Upper & Lower Sprockets
* Plastic Chain Guides
* Chain Tensioner
* Timing Cover Gaskets
* Front Seal
3000$ !!!!!
dude, you got ripped off. not to be an ass or anything. but my friend just got a 1994 toyota pick up with not rot, fuel injected 4 banger, five speed, and locking hubs for 300 bucks, the fiberglass on the bed is craking a bit but that is it. i think that 3000 is way to much for that truck. :doah:
he's in Canada, his dollar doesnt go as far as yours does.
BTW, Steve, skip that timing chain set. it has plastic guides, which were mentioned to be the weak link earlier. unless its SUPER cheap...
