... so I gotta order another pack for the other valve cover.
How he has them is how they were engineered. But if they don't leak, mehAre those spreaders upside down? The ones on my K20 are opposite from yours just curious if mine are upside down or yours are.
Edit-my valve covers don't leak either so who knows![]()
Are you calling me old?I didn't install mine they were already there just curious, I usually mess with the later heads with center bolt covers
Yep, good luck on the bottom end
I haven't "torqued" intake bolt ever. I do run them in order however
Looks good dude! You have been busy!
The block is good cause you can run the roller lifters easy and cheap.. Unlike us flat tappet guys without the bosses.
Looks a lot better after you removed the light bar.
Martin
I like it. Nice work dude!
