Nice finds
Hood don't look too bad.
Nice finds
What kid of lift does the 64s give with the shackle filp? I have a set laying around along with a set of 8" superlifts for the front... I wondering how well that combo will match up.
Probably? I can't say for sure. The wheel is correct.
Cheap. Slight amount of tire clearance. Is not nearly as noticeable as 2" or 3" body lifts. Makes it much easier to work on things under the truck.
Martin
I might just go ahead and do the 1" pucks just to get to stuff easier. Does it mess with any of the linkages or anything? I'm guessing not so much with just 1" more between the frame and body.
It is MUCH easier to work on things underneath with the 1" body lift.
My Suburban is a 4 speed (or at least it was by the time I put the body lift on), so other than the shifter being slightly lower than I was used to, I didn't adjust anything. My NP208 shifted just fine afterwards. I should have adjusted my fan shroud, but it was already damaged, so I just let the fan self clearance the shroud....
Martin
Those wheels are aftermarket.
Going to do a 1" body lift while you're at it?
Martin
Thanks for pointing that out, I won't feel bad about selling them now if somebody will buy them.
I don't know if you're able to tell but does the spare tire look to be original to the truck?
What are the benefits of doing a 1" body lift? I've always stayed away from body lifts and block and worked all of the lift into the suspension.
Thanks for the info! I'll need to replace the bushings anyway so I may throw some 1" pucks on top of them while I'm doing it.
Nice to see your making progress on the project.
Alot of work but its going to be fun. Your description and needs is pretty much how i ended up with my burban. I needed more seating than a blazer could give.
So did you sell that nice blazer to your brother?
Let me know if you need help wiring up the 220v. I wired my own at the house and I taught that shtuff at the school house for 3 years.
I most definitely will need help! I don't even know what to buy to get it started. I have open slots in the breaker box and want to run the wire outside of the wall through conduit.
