If the tires are shaking, you need more airMmmmm tire barks, my Greg trans does the same! On concrete it’s wild and I can feel the tires shake.
I’m probably going to do more across the interior. Back of the seats; maybe bedsides.I've thought about using those in some places too. Seems like they could be handy to have.
It’s so perfect dude. They pull the wave spring out of the clutch packs, creating the perfect shift feel without jacking around with the line pressure.Mmmmm tire barks, my Greg trans does the same!
After this trip to the PNW, I’ll have a feel for the truck across a range of roads and conditions. Then, it’s time for some Tom foolery.I see a 300hp+ dyno in your near future :-)
E rated tires they wear weird if they are above 28 psi on these 6 inch wide wheels.If the tires are shaking, you need more air
All hail layout fluid and transfer punches.
These prototype door cards are 14 ga while the molle panels are 1/8”.
David
Like a little cubby hole in the door cavity? I like that idea, and might make that a Rev1 project. The pouches, while thin, will intrude on interior space a smidge, so I mostly have slim fitting things in mind for the space - air down stuff, water bladder, flashlight, etc.I thought you were going to use the area inside of the door?
Martin
This is helpful. I understand them now. My Dmax oil looks like crude oil on day 2.Look at that clean oil. Those gapless second rings are doing their job.
David
Excellent point. I think it’s difficult to overstate the importance of clean burning injectors and the right injection/ignition timing for whatever amount of boost. It’s all in a pretty narrow range for adjustment, too. Ignition of 0.5* ATDC is hugely different from the same value BTDC.When things are adjusted well, the oil doesn't take on a lot of soot.
Better get yourself some white claws then.Also, I’m an overlander now.
David
Shiner bock seltzerBetter get yourself some white claws then.![]()
