Here is a quick rundown of the ORD rear bumper.
I like their design, and had some ideas for how it could be tailored to my truck. Stephen at ORD was very accommodating:
· Significant reinforcements for towing – enclosed center section with reinforcements around the receiver hitch and a place to connect chains
· Extended wrap around - suburban has a slightly longer overhang than their longbed pictured on the site
· Rear quarter panel protection compatible with barn-door suburbans – clears the open doors very tightly
· Frame tie-in tube shipped loose for me to mount – used non-flanged disconnects
I called Stephen in late January 2013 to discuss the project, and they had a barn-door suburban in the yard that they could use to mock up the bumper. I took delivery April 1st and got to work installing. For a custom tailored product, that’s a pretty darned fast build time.
The rear quarter panels were trimmed significantly and were about even with a rear body line covered by the factory bumper.
Additional porting for the reinforcement bars.
The rear spare tire well was boxed and plated and would eventually become the new home for my batteries.
I put some small pieces of 16ga blockers in the newly created gaps at the bottom of the rear quarters to keep out the big chunks of rock/dirt. Eventually, I want to trim and fit back in the rear lower quarters to create a more factory-appearing quarter panel with these improved clearances.
The bumper has done its job and protected the rear panels in some tight spots, and I’ve pulled several 6K lbs trailer loads of decomposed granite and dirt.
David
