One Piece at a Time: My 1985 Diesel Suburban
Heard back from M&D, and my pump is in good enough shape that it can be rebuilt back to full 4911 specs: .310 plungers and 68.5 cc of fuel. That fuel level is where I start to get it timed. Also, turns out the advance piston was well worn, which apparently led to the initial leak and it's relatively immediate recurrence. They honed that part of the housing for a new piston and seal.
Should have it back later in the week. Rebuild saves about $400. Pretty lucky/excited.
David
oohhhhhh........................... aahhhhh (say it slow like watching fireworks)
Would you take pics doing the swap...?
I'm building up my nerve to do mine.
It's not too big a job to tackle on your own. Just take your time, be methodical, and take notes. Also, cut a notch in a 16mm box end wrench and get a crows foot in the same size for the bottom two injector lines. Saves a ton of time.
I'll post my install notes.
David
Thanks. There's good info already....:thumb:
Pump is in and hood is closed. Probably the smoothest install and bleed I've ever done (knock on wood). Runs strong on baseline timing, and I might not have to adjust much more. I'll post pictures and some notes once I get everything cleaned up.
First, off to get a Christmas tree.
David
I just noticed you have a serpentine set up...
Nice work. I hope to be that smooth one day with my install.
This time was just good fortune, but I'll take it.
The 1996-2000 pulley setup is the best way to get dual alternators, and both are the same and widely available - GM 105amp. The CUCV brackets are difficult to find, and uses a less common and larger frame alternator. The later model civvy setup is designed to fit with dual thermostats, and required minor modifications and fabrication to fit on my mechanical 6.2L.
David
The pump has about about 10 heat cycles and around 100 miles - all running great.
While there are several injection pump swap instructions out there, I'll focus on the things that I've learned that make the process it go more smoothly. There is plenty of chance for error, so I'll repeat what we all know helps any project - go slow, be methodical, and take notes.
Disassembly:
  1. Disconnect power
  2. Remove intake - it's been a while since I had the intake off, so I made a quick diagram of where the hardware and grounds wentFullSizeRender (1).jpg
  3. Plug or fill all 8 intake ports and the 2 exhaust crossover ports. I used duct tape.FullSizeRender.jpg
  4. Remove throttle and high idle hardware and the kickdown cable if you have it
  5. Remove oil fill and carefully remove the 3 screws connecting the timing gear to the pump, rotating the engine to access each screw. I rotate at the flywheel; some people rotate at the crank. I do not recommend bumping the starter.FullSizeRender (2).jpg
  6. Disconnect injectors at the pump (16mm modified box end, and matching crows foot for the bottom 2 lines (or 5/8", which fits tightly)
  7. Loosen lines at injectors 1, 2, 3, 4, and 6 and 7 if they're easy to reach; now the lines will move a little and allow the pump to come out more easily
  8. Remove the 3 nuts holding the injector pump, and carefully remove the pump. The pump fits tightly in the timing gear, and take care to not disturb that now loose timing gear too much that it jumps a tooth from the cam gear - very difficult to do, but if that happens, you'll have to pull the accessories, water pump and plate, and reindex the timing gear. Just take your time.
  9. With the pump on the bench, remove the TPS, rear supply fitting, and
Get your pump rebuilt by an authorized Stanadyne dealer, and take the opportunity to get the 12 point 15mm nuts for the pump to timing gear. Get a good set of torque wrenches - 3/8" and 1/2" - or make sure yours are still calibrated correctly. I like the Craftsman Digi-Click.
Reassembly:
  1. While the pump is away, I use a 3M scotch brite blue disc to clean the gasket surfaces - heads, intake, upper plenum. The front cover cleans up quickly with 600 grit.FullSizeRender (2).jpg FullSizeRender (1).jpg FullSizeRender (3).jpg
  2. Vacuum each intake port, the valley, and surrounding area - just in case there's some grit or junk that found it's way in there.
  3. All gaskets go back dry - leave the copper, permatex, and RTV on the shelf. I've tried them all, and they don't help on the intake side. I've only ever used FelPro.
  4. I put my TPS back on at the bench before installing the pump - whatever works for youFullSizeRender (3).jpg
  5. Rotate the pump to align the dowel pin with the timing gear
  6. Carefully install the pump onto the timing gear and front cover - take your time
  7. Torque the injector pump to timing gear screws to 20 ft-lbsFullSizeRender (4).jpg
  8. Align the timing marks on the pump and front cover - should be 0* BTDC, a level suitable for both NA and the vast majority of turbo setups. Err toward ATDC (tilt the pump one line-width to the passenger side) if you make a lot of boost (>15psi) and/or run greater than 70cc of fuel. One line-width is about 1.5*-2*.FullSizeRender (3).jpg
  9. Torque the injector pump body to front cover nuts to 30 ft-lbs - you can't get a torque wrench on these, so I just make sure they are reasonably tight
  10. Reassemble injector lines to the pump - start with the bottom two and work your way up and around.
  11. Retighten lines at the injector, except 1 and 3 (those are the two you'll bleed for startup and are the easiest to access)FullSizeRender (4).jpg
  12. Reassemble throttle and high idle and the kickdown
  13. Pull the plugs or shop rags from the intake ports and reassemble your intake following the factory torque pattern - I go in two stages and do a retorque after the first heat cycleFullSizeRender (2).jpg
I recommend doing the first fire without the intake - makes it easy to check and resolve leaks at the pump. Just get your grounding hooked up, and you can operate the engine without the intake. I leave the serpentine belt off, too, since I'm usually laying across the radiator checking for leaks with a flashlight.FullSizeRender.jpg
Regarding bleeding and getting the first fire, I have an electric pump, and bleed first to the filter. Then, with a helper cranking in short 5 second cycles, I bleed lines 1 and 3. Next, it's usually only one or two 8 second cranking cycles should get the engine started and it will chug out the rest of the air. If you're doing this with the intake off, you can see the exhaust crossover ports start to puff and confirm you're headed in the right direction.FullSizeRender.jpg
Here's the one 8 second crank and first fire:
All done and back together.
I'm sure I've left out a few things, but I hope this helps.
David
