Onetonbb74s K5
1 ton k5 built for wheeling and camping.
Took it for a cruise this am, seems fine. Now im going to pull the rear shaft and have it re-balanced.
I might end up getting a new one so I can use the old rear shaft for a spare.
Im going to check that first. I think my angles are off as well. I hear a decent amount of gear noise in the cab.
Also got the bender mounted on the slab out back...used 1/2 inch drop-in anchors. Probably fill them with antiseize and grease when the bender is in the garage...20190316_155339.jpg
What are you guys doing for a degree wheel on the bender?
and who makes that tool bag? I need one of those and I've only found one company that makes them and they're waaaay too proud of their stuff.
Atlas 45, and there very proud!
