m00nBlaZe
Registered Member
So what's new with this build? I'm eager to see how this rig turns out
So what's new with this build? I'm eager to see how this rig turns out![]()
Nice progress, looks like a lot of clearance issues to do with in the front.
Also, I had fits with my stub shafts but the opposite, they snap rings weren't holding the spindle seals up against the spindle, way too sloppy. So I hear you.
And those dynatrac hubs don't have any indicators?
side ? i read here http://coloradok5.com/forums/showpost.php?p=2931687&postcount=65 that stephen had a problem on long trips 1 time with 203 range box over heat ? was this mostly the exaust heat transfer or also nature of the box when we install it as a doubler setup ? i plan on dd use some with my setup . dont need a problem.
but the wife wouldn't let me
Always wanted to do this to my 97 but the wife wouldn't let me
We haven't even started talking about custom spacers to keep the stub pulled out and the spindle seal pulled up tight.
The dynalocs have Xs and Os on them for indicators, they just washed out in the pic. Makes me think of little girl text messaging rather than locking hubs but it's good enough.
That's exactly what I did after talking with you, since I got all the axle parts from you guys. I made sure to have enough spacer to keep the seal tight, but small enough that it has room to move around a little. It has been working fine since.
Build is looking good by the way, I like it, and not much waiting to see the results either!
