it's pretty busy in the shop right now but here are a few pics of where it sits now.
This was the most awesome trans fill job ever. I haven't messed with a manual that much and this might be their best feature.
This is one case that the Amsoil juice might be cheaper than the dealer fluid that the 4500 requires. Their allison spec fluid is the same way, the "torque drive" that I run in my ZF6 in the tow rig.
Power steering cooler is mounted and plumbed so that system will be happy. All AN8 return lines with full flow fittings so it's about as happy as it can get.
The 180 on the end required some trimming on 2 of the fins but it makes the line routing work great. These log coolers are a pain to plumb without this trick.
The bed is just about ready for paint, shock res mount are on:
We had a big weekend for finishing up wiring and plumbing. We got this pile of hotness:
Luckily they have a pretty nice harness system in addition to some kick ass lights so they're not hard to install. Now we just need a bumper to bolt them to but that'll probably happen tomorrow.
Alex Santiago came back over for a couple days and fit all the switches and wiring under the hood and in the dash. With a little trimming the switches fit right in the factory hole.
That's got the BD Prerunner HIDs on the top, the LED bar switch and mode button in the middle and the ARB compressor and locker switches on bottom. The extra on the left is for the clutch safety defeat.
This side of the dash has the fan control switch for the extra cooling fan in front of the radiator. On-off-auto. The computer will turn it on at 206 now instead of 230 or whatever the factory setting is too.
There was a hour meter in that hole to start with but we don't need it anymore.
The parking brake is now gone since the discs are on so we put this line lock valve on the A-pillar for the rear circuit. Bleeding will likely be a pain.
Shifters for the 203 and 205 are in now but this is how the holes laid out. The shift handles ended up being pretty convoluted to clear everything just right. I'll get pics of that later.
Back to the grind for me. Lots of little stuff going on now like running brakelines and I started on the 2 link traction bar system earlier and need to finish that today.
