You should check out airbagit.com
They have this sweet long travel kit for a 67-87 2wd front end. Would prob work great in the sand
Will do
Thank goodness all that driveline weld talk ended... 1000hp big block on 16" wide slicks? I would have given it a second thought. A sand truck with a fairly mild SBC? **** aint never gunna give up the ghost!
completely stock tbi 350 with 120k on it and 4.10 gears with 33" max tires lol.Thank goodness all that driveline weld talk ended... 1000hp big block on 16" wide slicks? I would have given it a second thought. A sand truck with a fairly mild SBC? **** aint never gunna give up the ghost!
No biggie daveAdam, I ain't got no headers!
id like to get some measurements and start drawing some 3d cad models and post em up. Im not quite sure how the angles are supposed to work though. Ive never understood why the top and bottom control arms cant be the same length from the frame.
wouldnt it just keep the tire completely vertical the whole time instead of all that goofy angle when the suspension is goin up and down?I would put the biggest tires possible on.
I have no problem making a new cross memeber.
And most likely making my own control arms. I just dont quite understand the differance in lenghts of the upper and lower control arms. Why cant they be the same lenght from the frame and run parralel to one another?
