ChefBear
Lift
I made hella progress for 2 days and then it kinda came to a halt over the holiday weekend. I didn't get the right spring plates to put the stock running gear back, brake line didn't fit, and I found a great deal on a 14 bolt and 3/4 ton front so... Might as well, huh Greg?
It'll take me longer but I'll only end up doing it once and buying stuff just to run around for a month or two before buying it again didn't make great sense. This will give me time to finish other projects and wire in the dash etc etc...
Shakle flip was easy. Wafer disks on the grinder sliced the heads right off the rivets and an air-hammer pops them out nice.
E-brake is super tight. How do I extend or cure that?
I need to stay focused and resist the AD/HD sidetrack syndrome, cause I know the next step would be a nice maple burl steering wheel and matching knobs for everything, but I did end up spinning some walnut and drilling out the center to hold the LED turn signals and recessing that in the stock location.
