y5mgisi
1 ton status
Nice parts though thats for sure!
Damnit! This is unexceptable!!!! You cant fab like you did then not give us more of the same!![]()
Nice to see another rockwell build on here
Need one of the drool smileys right now!
Will you be keeping your 2.5 tons now that you have moved on to a buggy?
u act like you have othere things to do! Like you have a life or something! Sheesh!!!
Some people are inconsiderate as fock!
Man... Everyday i log on. Im hoping youve updated!u act like you have othere things to do! Like you have a life or something! Sheesh!!!
You have no idea how badly I want to get these spindles worked over so that I can bolt the axle up.
Bad freekin A!!!!
Pure curiosity, but do you lose any strength by doing this?
Martin
The links look like they will hit the steering...![]()
Haha, I still need to build a set of high steer arms off of the king pin plate with a tube running down to the factory tie rod location. The outer heims will mount somewhere along that tube, so they should come up a couple of inches to give more clearance.
