Have someone that wants my 10 bolt axles so I got busy and had them out in about 2 hours using my cherry picker and some jack stands. Got the 14b under there temporarily. I still have to weld in the spring perches but have to figure the driveshaft angle first. So for now it in sitting on the perches unwelded, slightly snugged up. The front 10b is out with the exception of the tierod bolt. It came most of the way off the bolt then started spinning. It will sit for another day before I can get to it. Today is work then straight to school for 4 hours.
After I get the 10b gone, I will swap in the new custom ORD/Alcan springs beofre the D60 goes in. The rear still have to get the shackle flip installed. I'll drop the gas tank and get it out of the way before I start grinding rivets and welding on the rear spring perches
