OK, so it just finally clicked in my head. I have been seeing a video of this truck mobbing hard in the snow, and I just now realized it's YOU!!! Lol
Looking good man!
Looking good man!
Looking good man!
Thank you!
The mirror is from a newer chevy that has auto dim, compass and temperature. Also got my other fan in. Its a 16 inch fan I'm going to use as a pusher fan. Hoping it will be enough to keep it cool now!
I may end up switching them around and use it as a puller and the other 2 smaller ones as pushers.
There was virtually no wondering/swaying on the highway so far where as there is a little bit in town with the divots worn into the road. I am very happy with the gearing I chose as it does well for cruising on the highway and still has a good low speed in 4lo. It was right around 2100 rpms at 65-70. This is a trip we do every year and was a good one to test it all out on since it’s a mild trail that doesn’t have a lot of hard areas. Drove it around for a few days on the 2 different trails and it did really well. The only 2 problems I had were the 40s rubbing A LOT lol, and I had a hydro assist fitting come loose. So I ended up beating the crap out of the front fenders to get it to not rub for the rest of the trip and just tightened the fitting back up on the hydro assists. I have new fenders for it so these are mainly just test fenders to see how much I’ll need to trim. All in all I think it did very well and I’m impressed with how well it even handles off road with the 52s up front. They are very flexy and ride a lot smoother than the other springs I had in there. Would definitely like to get some longer adjustable shocks on there soon because it’s lacking in that department! Also on a side note having the stock power steering pump on this trip sucked since it’s not enough for the whole system but my new one should be in this week. I’ll have to get some pics of the awesome custom fender work I did but here is some others I took. We also brought our fleet of dogs with us lol
That's a big ole compressor! What did those come on?
Still have a bunch of wiring to clean up and put in looms.
When I put the Sniper EFI on the only spot I had available for the temp sensor was on the side of the block and it put the sensor wayyy close to the header so I picked up a thermostat housing spacer with 4 ports so I could move it up top away from the header so it didn't melt it and it also gives me a few extra ports for when I add a different temp gauge. Since I still have a bunch of wiring to get cleaned up I started making my relay panel so I can get the rest of the wires ran. I've used these relays before and I must say they work awesome for keeping the dirt and water out! Hopefully 10 will be enough for everything I want to do. There is a couple extras for if I add anything down the road.Am I seeing those switches right - the housings are 'stackable' ?
You could just weld the distributor to lock it out. That’s what I did in my race car.
Edit: didn’t see the second post that you went with a smaller distributor too.
