pma4x4
AKA Yankeeroad
Muddysub
Its actually really easy to get to the front striker nuts.
Pull seat forward
5 Phillips screws on main pillar panel
1 screw above seat belt bolt
remove seatbelt bolt. 3/4" socket I think it was.
panel pops loose and slides out of way and you can stick you hand in enough to hold it the nut.
Nojeepshere
there is a nut on the inside of the pillars that the door striker screws into. the striker goes thru a larger hole so when the striker is loose its adjustable in all directions.
The nut on the inside of the pillar is typically captured but a sheet metal "bucket" that is spot welded into place so if you fully remove the striker bolt the nut just flops around in that "bucket" instead of falling to the bottom of the pillar thus requiring you to fish it out with a magnet.
Most car companies have these nuts captured so you dont have to tear apart the "B" pillar paneling. For some reason Chevy didnt in this specific model and/or year range. But like I told Muddysub they are easy to get to.
hope that explained it for ya.
Pull seat forward
Nojeepshere
