Ok I know the thread has been pretty quiet lately. I've been taking care of the business side of stuff and the new engine project has been getting a lot of my attention.
Here is the build list so far.
(UPDATED 07-05-2014)
We have found out our Suburban (as great as it is) is just out of power when loaded down and hitting the hills.
We decided to go with a SBC just due to the fact I found one real cheap and I don’t have to switch much of anything on the truck. Other engine ideas were explored, 5.3, 6.0 7.4 vortec and even the 8.1. The deals I ended up with for the main parts of this project just said “SBC”.
Below is the initial list of parts. I have already spoke with Compcams and TPIS. With all the info and weights I had Compcams recommended the cam in the list below. I have been doing some serious research even picked up a few reference books. Now this is not my first time building a motor but it is my first time building (per-say) a fuel injection system. If you see something wrong or I am missing please don’t flame me as this is my first initial list of something new. Input is always welcome.
Engine short block: 99 5.7 Vortec
Heads: EQ CH350C Vortec Heads (with pre-'87 intake bolt pattern)
Cam: compcams XR264HR #8-501-08
GMPP Roller lifters #12499225
Chevrolet Performance Timing Chain Sets 12371043
Est 9.5:1 CR
90-92 Tuned Port Injection
Stock runners
Stock TB
Stock Corvette (Pre '87) TPI intake
24lb blue top injectors
BBK Adjustable fuel psi regulator #BBK-1714
Speed density setup
1227730 ECM
All new sensors.
Other stuff
ALDLdorid app
Tunerpro on the laptop
1320 Electronics ALDL Bluetooth transmitter
The block is already at the shop. I am actually video logging the entire step by step build with them. Pretty much all the parts are more or less stock and is not running me much more then a regular rebuild.
Aside from the one TPI I have I just picked up another pile of TPIs. a full TPI unit from a corvette (85-86) standard head bolt pattern. and a spare unit minus plenum for F-body heads. It was a good 4th of July. $120 for both. already sold one of the throttle bodies and this just saves me spending the 400 on the Scoggin Dickey intake manifold and I should even make money on the left over parts.
