Grand rapids, MN. The whole idea is to hit the North shore during fall colors.
Should be beautiful. The whole Northwoods is at that time of year. Should be a great trip. Definitely post pictures up.
I am running the same amp and an Alpine receiver. I have 4x10's in the rear and the dash speakers have magnets so big I thought I might have to trim. System sounds good but it takes a lot to make up for the wind and road noise at 70MPH even after all the insulation I have in this barge. I think I may be headed back to some 6 inchers in the doors and a small sub eventually , or maybe I should get a hearing aid![]()
. just roughly 60 hours of digital music.
The front speaker mounted up fine depth wise. The raised tweeter was the problem. I want to lay the dash pad back down and the padded speaker grilles were so brittle the tweeters just popped right through. This was not much of a problem for me as I just received the new molded plastic dash cover from LMC truck and that gave us new speaker grilles.
.I have been thinking of doing this exact thing so I have a couple of questions.
With the "custom clearance" of the dash pad there is enough room for the new plastic cover not to contact the speakers?
Also, how do you like the plastic cover?
By the way, I am thoroughly enjoying the direction of your build, taking notes and stealing little things here and there.
Thanks for the ideas.
Did you say you were going to re paint the truck?
What color this time?
I will say this, if you go with USB flash drive for music get a low profile one like this Scosche. I almost snapped a regualr sized one off with my knee.
