You'll need something stronger than hose clamps if you're pushing 65psi for EFI
I run a TBI for now but the plan is to LS swap in the future and don't want to do this twice, also I ran the Walbro 225 pump in the UAV with TBI and it ran great.
No angle on my tank, same measurements as the new 31 gallon tanks so assume that is what it is? It also has baffles in the center.
I was waiting to see if anyone was going to correct this.Hmm, I thought it was a TBI sending unit because it has 4 line outs, what else would need that? Some other fuel injection model? The plot thickens
Keep in mind the 2 fuel lines with the nuts at the end have been cut off.
Oh and yes Walbro 255
According to the dimensions you're right it does look like it's a 25 gallon tank, just need to find the correct sending unit for this size tank.
Yeah, the tank has a baffle trey in it.Rock auto has sending units for 25 gallon or 31 gallon, just look up an 87 blazer.
And you are correct on the sending unit, I didn't realize the metric nuts were cut off.
Does that tank have a baffle for the pickup?
I have ran those type of fittings with no issues but always bought the Earls version. I dont think they are much more money than that.Proof you can run a Walbro 255 in a stock TBI engine with internal stock regulator. I realize its a 4.3 but similar throttle body and regulator.
Has anyone tried these adapter fittings on Amazon?
Thanks! Steve was asking if they still sell the factory braided lines from the tank these days but I didn't think those lines are still being reproduced. You can always get used braided hoses only but then you have 40 year old lines that could leak down the road. I realize you can do the -6AN conversion with those adapters (pic below) which is what most do or go to barb fitting to rubber line after the -6AN with another adapter.Earls are good, I use Fragola or Earls depending on what else I am buy with it, they are both good. Fragola has a better price and is a USA made product. I don't trust the overseas stuff with critical plumbing.
Why are the colors swapped?
