Outrigging the mount isn’t an issue as long as you brace it properly.
Are you using the radius arms?
If you are, you can have the attachment point on the frame narrower by an inch.
I’ll call ya later, finally getting caught up from the weekend!!No I'm building my own links. I can build an inch inset into them with no issue. I would like to NOT have the outriggers if I can help it.
Resist the short arm thing.. you’ll have to drop them down to get any sort of decent angle, also as the travel at droop it will pull the axle and steering back towards the cab much more quickly. A long arm will ride better and have a much better recession curve than any short arm.For the moch up, Everything will get bolted in with grade 8 hardware. Once I am satisfied with the way it works I will weld it in. Mounting the brackets under the frame will not only look cleaner but will be stronger in the end with a plate welded to the inside. I'm seriously leaning towards short arms the more thought I put into it.
May want to remeasure your frame, I dont think the stock frames are that wide in the front. On my square body my frame is like 28, leaf perches are at 32 and out side the frame in the front and under it in the rear of the front leafs.
OK so its 34 for the spring plate mounts. Inside of the frame is 28 or so lets say 30. Still puts the diff right under the frame. You are going to have nothing for up travel in order to keep the diff out of the frame.
Where I am going is that the pumpkin on that axle is going hit the frame. What is the measurement from radius arm to radius arm? Across the axle.
What is the width of a stock frame under the engine ?
OK, good luck have fun with it.
Ya know I typed a bunch of stuff then just deleted it all, the basis is this. You're wrong.....LOL I'll just leave it at that. I'm not going to explain to you how I know, it isn't worth my time to do so. So keep reading along like everyone else and you'll see how I get around it. Then I'll quote this post when it's done.It wont fit is my point, that is why I said measure it. My truck with stock springs in the front which are rear stock spring, which gives it five inches of lift over the factory set up. The differential hit my oil filter. That axle's diff is wider then mine it, is also a high pinion just like mine. The top of the diff, it would appear to me, and the measurements I have seen, will be hitting the frame at pretty much any amount of compression. You may want to go out and get some compression measurements off a stock set up and see how much they really move. You say you want to build a set up that ride like stock so see how much stock really moves.
Once you get a rough idea of your link lengths then you can estimate travel and deflection.
I realize it's not a long travel rig. But you gotta build it so it's reliable at the limits.
There was a guy at Blazer Bash in 2016 from SLC that had an orange '72 K5 with a ford dana 60 front. I think it was from a super duty. If I remember right he had coilovers. I am not sure who he is on here. @ashman might know more.
