I wonder how bad icing may become with all these efforts to reduce intake charge temp? May not be an issue where you are, but others have said that removing enough heat from the intake/inlet air temp has caused icing problems.
Eliminating crossover will disable EGR, if that matters for you.
I'm running a 465, the crossover is almost resting on the bellhousing (within 1/8") no issue really tucking the 2.5" pipe up there. Making it look pretty and mating up to the collectors nicely on the other hand...
1% definitely differs from the 1HP per 10 degrees that is oft-quoted, but makes more sense, any increase in HP has to be proportional to the initial HP rating. And would be quite significant if you could achieve anything over 5%.
