Good point.
For a cage yes because it needs to work in every direction.They do not allow roll cages to be built out of square tube for reason.
How did your springs like that?
They got it twisted but bounced right back.
This is a good problem to have - this means that the combo of a 4-spd, roller big-block, 5.86 gears with a spool, 56” springs and big tires are all working together to give you this issue!That ^^ sums it up. It wasn’t real violent but it wasn’t good, it didn’t hurt anything. (knocks on wood)
If ya had a 305, TH350 and 2.73 gears it wouldn’t be anywhere near as much of an issue…needing a proper traction bar setup is a badge of honor for an effective build sometimes.
Yeah, but having a motor like that is like marrying a smok’n hot stripper - it’s AMAZING & FUN but ya know deep down that it’s sooo much more upkeep, expensive and not good for all your other parts in the long run and eventually could kill ya…but it would be cool !You’re right it’s working ok but I was hoping for a little more shock and awe, like back in the day.
#morecam
#needtowakeitup
#mightaswell
I love my ord 2 link traction bar, Facebook said it wouldn’t work being two fixed points.
must of been blind and missed the SHACKLE ..... but they all love them fixed non swinging traction bars for the street .I love my ord 2 link traction bar, Facebook said it wouldn’t work being two fixed points.
I have no shackle on my setup, it uses a leaf spring bushing and a Johnny joint on the other end, I have two of these one on the driver side and passenger side. The suspension cycles 13 inches of travel with no binding.must of been blind and missed the SHACKLE ..... but they all love them fixed non swinging traction bars for the street .
Correct, the springs and bars move in the same arch. Lots of cycling the springs, I would use cardboard and a sharpie and trace the arch at full bump and droop, when the lines matched, I found the spot.I think I understand it. The spring changes length and swings through an arc. The bar is a different length and mounts at a different angle to create nearly the same arc. The bushings will have to give a bit and the pinion angle will change a little bit, but all close enough to work fine.
