ReTonkulous
Utlilmaster P30
So at what point do you buy a new harness? If that’s even a thing for this thing.
I have said "this should be the last of it" a couple of times now.
This is where the weather pack plug will go to shorten the harness.
I still have not found the failed ground.
That’s why you make the big bucks… fixing OPs F ups.
Crappy thing is it yours now and you can’t invoice it to a customer.
Good times! :doah: Nice work cleaning it all up! :waytogo:
The worst is when the PO is you. I've fixed plenty of crap that I did while younger, poorer, in a hurry, or some combination of all 3. The whe time wondering what the he'll I could have been thinking.
Did not get started until after noon. In 30 minutes, I pulled all of this out.
Red=ground.
Black=hot.
White=ground or hot.
Was just going to shorten the rear harness now that it all works. Started chasing the brake controller wires. Black and white. Should be red and blue.
This was an attempt to lengthen an amp feed.
