y5mgisi
1 ton status
I seem to remember that they supplied you with a dished plate, and you swapped it to a flat plate. There has to be this spacer between a flat flex plate and the crank.
The spacer is between the crank and flex plate, I have a 4L80 flat flex plate.You didn't just bolt on a flat flex plate with no spacer did you? Again, there HAS to be a spacer somewhere In the mix. Between crank and flex plate if flat, and after flex plate if dished.
I figured as much, CenCal style doesn't mesh with CK5 style all that well, but it's all good. I've always wanted a set of Dunes.Too blingy for me. But If they are just temporary....
I'm getting very close to starting the 6L. Fuel system is in, the deal on the fittings is I just had to push like an angry animal to get them on. I had to dig out my old double flare tool to finish the fuel system.
Got everything wired up and turned the key on, fuel pump came on for about 4 seconds, everything looking good so far.
More questions.
1. What are you guys doing to retain your FACTORY oil pressure gauge?
2. What are you doing to retain your FACTORY coolant gauge?
3 Guys running a 700/400/350 trans, what did you do about your tranny dipstick? Mine is not going to fit as is, I'm going to try straitening mine and start over with new bends.
If you have details in your build thread please give me a page or post number to find it. Some of these build threads are getting 100+ pages and are like a needle/haystack trying to find info on one thing.
I actually dont hate the wheels so much, just 99% of the time the people with those wheels are massive bro douche bags. I know you are not one of those so its all good lol.
Any pics?BWD P/N WT5121 for the coolant temp. Three wire hookup, two for pcm, one for gauge. Clean and simple.
Yep, unfortunately there are a ton of those guys running around here. They have $80K Dodge Cummins for nothing more than driving around and making smoke. Most of them are flat brim hat wearing idiots.
I definitely do not fall into that category. We run diesels because we work them farming. But, I do have a love affair with Welds. Everything I have has Welds, except for my service truck (10 lug) and the wife's Escalade with the factory 22's.
You wear flat billed hats? Lets be honest here. It's not the truck that makes the douche bag, it's the douche bag that makes the douche bag.I was gonna say "because I know you work on a farm" lol.
I generally hate all of those guys. I myself do wear many flat billed hats, but I still run a 30 year old rig with hubcaps. So i think im a bit different![]()
