And so it begins.....
couple things I was very glad to see was hydroboost and the second battery tray... tho I may relocate the bat/s at some point anyway...
felt like there was hesitation, like timing is off.
runs a ton better now that the firing order is right...
still has a bit of what I refer to as the voot, voots... not spinning up right... but at least it stopped shooting fireballs out the tb now...
new plugs... tomorrow night I'll check timing, forgot my light today... new belts and cap/rotor tomorrow too probably..sooooo. been bangin on this the last few nights.... plodding thru LOT'S of maintenancey, cleaning, etc.... ancient piss oil change done... entire truck drivetrain degreased with easy-off and hot water... motor, 205, x-members, etc, etc...
changed the 465 fluid from ATF to Mercruiser performance gear oil...
bunch of exhaust leaks to deal with... trans mount had no bolts in it...runs a ton better now that the firing order is right...
been hacking out a bunch of wires to nothing stuff.... chopped the frame and started laying out the temp bed... i'll finish that this weekend, maybe get the new back springs in... gotta figure out some fills for the saddle tanks after the bed is on...
hey bud.. yeah, the tanks are a bit voodoo at this point other than throwing 10 gals of fresh fuel in each.... and somewhat fixing that cut fill hose, x-overy set up to keep sh*t out... once the deck is on, i'll do a fill on both sides and ditch the tube..
and ok, cool, i'll check out the pumps, haven't even looked at either.... i did switch the dash switch at one point, but I'm not sure which position it was in.... i ran it a bunch tonight tho... not even sure what tanks it was off of... i don't know d*ck about dual tank systems.. first I've owned.. and I'll be ditching it by the end of the summer.... i'll just figure out which tank/pump is working and ditch the other side alltogether... i don't need the capacity now...
and yeah, #5 and #7 where crossed... haha, the injector harness/plugs are pretty freakin toasty at this point... i'm gonna splice in new injector plugs pretty quick...... water temp sender is busted.... i'll get one of those tomorrow too...
hey..... wtf is that slideknobby box thing under the column with the light on?
super clean frame and underbody..... i mean it needs some sanding/blasting but solid as he!!.... i may use my old K5 flat hood... this ones got this goofy crack in the sheetmetal in the front.. never seen one do that before.. very fixable, but i may just use my other clean one with the fuel pressure gauge on it...
oh, pm with what overnight tracked costs when that comes in, i WILL send you money for it... need to retire the Nogo pronto...![]()
he liked the truck...which model is it?
I might have one here in my pile.![]()
don't sweat it.... i have a pretty good in for AC stuff...
