eh, same advice, burn the front, release, voodoo dance, etc...
if it buckles...where is it likely to distort or buckle? What do you do if it does?
I need to raise the body line just a little...do I weld it top middle or bottom first?
I think I can lift the body line by prying with a screwdriver through that trim hole.
eh, we'll cross that bridge if it comes.. generally you'll see it in the path of least resistence or at an angle... usually up from one of the wheelwell corners at an angle...
just see how it does jacking up the tailpan once fixed in the front.. you maybe surprised with it..
yup.. you'll know in short order.. it wont buckle from just releasing the bolt.. jacking the tailpan if needed, could do it if it's too much torsional stress...
your thinking too far in advance.. deal with that it if it arises.. one step at a time..
I'd loosen the other side at the tailpan, and maybe the next pair forward of the tailpan before trying to lift it to get the last body mount re-installed...
OK...I can handle distortion I just don't want to tear it.
