should I leave the fender off for now?
if the bottom of the door to rocker gap is even.. yes, put the fender back on and get a good gap... you wont be moving the door anymore..
keep in mind you have tailgate gaps to deal with too...
the rear mounts are both stock components? no triple spacer shims or anything?
if you free the whole front of the qrter, will the bottom want to close up without the screw drawing it in?
i think i got it now... when you tried to hang this qrter, what was the tailpan status?
it would make sense.. which would have no reason to be keeping the qrter up...
and you say the old qrter was like that too?
f*ck it, fill the bitch.. it's only a tapered bit in a jam.. just don't put anything in the bottom joint.. just 2 beads of seam sealer in there..
tomorrow pull the back mount out, and see what it wants to do with nothing in the back...
