Its for sale he forgot to mention, rather cheap too.
How cheap?
How cheap?![]()
Are you seriously interested Ethan?
It's an 84 454 4 speed 205.
Definitely not until the other truck sells. Need to thin the herd before I can pick up another one. But it sounds like a good starting point.![]()
Me too! It'll be great to have a real shop to work in, and give the garage back to the wife.
I think there's a mouse in your tailpipe.
looking great Eric....and YES, once you get it buttoned up and some heat going, you'll be in lala land, just no sippin fruity drinks ok?
If using OSB. Go 16 on center but stagger them. 6" sills with 4" studs. Wrap the insulation under every other stud. Keeps solid wood transfer from outside to in down to almost 0, for the best insulation. And same with sound.... But it gives you 32" centers for inside mounting studs.A question?
I need to build stud walls to hang OSB and sheetrock on and for additional insulation.
16" center or 24" center and why.
Remember these do not support the roof at all. This is a pole barn.
