Shop build. HEAT!
These global industrial butcher block tops are what we use for our mechanics at work
https://www.globalindustrial.com/g/.../butcher-block-work-bench-tops?trackType=null
They hold up to a hell of a beating and most are still being used that are 10 yrs old or more. Not bad priced either.
I personally don't like metal tops for tearing into things because stuff slips off, Mars your surfaces, and it's noisey unless it's 1/4 or thicker.
I actually priced some and once I pay shipping I could have 1/4" bent how I want it for a similar price!!!
I don't mind thinner metal tops for stuff. I plan on having it bent all the way down the lip of the table so it should be nice. But lots if other stuff first
Also I got fancy here on this shelf.
Usually for me I do this as easy as possible but there are some things I'd like to start doing.
Such as the edge on this shelf. It needed a bit of stiffening but I also wanted a lip above it. So I cut a groove into it with the table saw. Never really done that before. Took several passes. But it fits pretty tight.
I think I'll do this on other shelves too. But a smaller piece, and a deeper dado
Did you use a dado blade or just a normal one?
I've cut 'em offset like that to make them easier to screw into the OSB. I'm guessing Eric has similar reasoning. :thinking:
Either that or he just doesn't care about symmetry. :haha: :rotfl:
I didn't have the proper bit or a long enough screw so offset it is.
Good greif haven't updated this
That's a crew cab one ton with a hideous winch mount on front 9 ft service bed with a huge bumper. AND IT FITS!
It is so nice to have room
A table I got from a buddy which matched my little bench almost perfectly.
The hard part now is keeping stuff out as much as possible so when I'm done with these trucks I can get back to finishing the shop!
