PapaSmurf
4) Thanks Phil. I'll PM you. I have a question about the ground for the dizzy. I don't see one. I think my spare green wire is for a tach. I have my autometer tach connected to the cap. Is this right? It could be grounded through the body, via the hold down collar. Unsure... There's no ign box btw.
yep tach lead comes off the cap, and it grounds though the dizzy body to the engine my dizzy is out of a caddy with a msd coil and cap a abomination of sorts, use a voltmeter set on ohms, check resistance from the dizzy body to the neg battery terminal should have 0.50 ohms of resistance or less. if its more than that (mine was) my cap had a terminal labeled with a " - " which i checked and was grounded to the body of the dizzy so a spade connector and some wire i ran to the ground on the frame.
I have a timing light, but it wasn't running, just firing while turning over with the key. I had the dizzy set right, just wasn't advanced far enough. Never done this before and was surprised how far I needed to turn the dizzy. It's now running and timed at 8*. I ran it for 10-15 minutes or so while at 1500-1700 rpm. I had 55ish psi oil pressure while warming up. I let it get up to 195, which it held for the rest of the time.
and kinda scared. It's a new Mellings pump, it's what my uncle normally uses. It's running CompCams break in oil, 10w30 I think it was.
The oil pressure dropped some shortly after this. 12-15 psi at 195* idle. Is that ok? Double checked, 10w30 compcams break in oil w/zddp
