WA SOLD Dana 60 and 14 Bolt with ORD Cross Over Steering etc.
PNW Ochre 72 k20
Ellensburg Washington
Hi there,
I have since sold my 72' and will no longer need the axles or parts. It's a Dodge Dana 60 with 4.10 gears. The rear is a 73 14 bolt with 4.10's I have the ORD crossover steering and the ORD shackles to make it bolt in to a 67-72 as well as the steering box brace dana 60 u bolts/ studs etc. I also have The Ruff Stuff 14 bolt kit. (perches, shock tabs, u bolts.) I have the 2wd power steering box needed to run the cross over as well as new lines and power steering pump. I have included the ORD order invoice so you can see what is all included. The axles have always been stored in my shop or under cover since I have had them.
I am asking $2,750 OBO. That seems to be what a set up like this is going for here in Washington State. I will not ship items. Local pickup only.
I have a tractor and am happy to load the axles for you.
Thanks!
Call or text is preferred.
I am not on here very much. (425) 773 0769
  • OFFROAD Design parts Order.pdf
Sigh....wrong side of the country....
