129.5 burb vs 132.5 Longbed Single cab
If you move the body back 1.5" then you would need to
extend the steering shaft
lengthen the tcase linkage
figure out your trans linkage
It would move the frame kickup even further into your way
Throttle cable could be to short
Pushing the body back might make the rear body mount even further from hitting the frame
Seems like a lot of work compared to bolting in the axles and drivetrain and having the CUCV rear driveshaft shortened ( about 50.00 ) and welding on new spring perches.
