Ok, So I got the "repair clip" and the new TV Cable in the mail today. I installed the repair clip and adjusted per directions. The cable was so stiff that about half way through to WOT it broke the repair clip.
I didn't expect much from a $1.00 piece of plastic.
SO, I went ahead and replace the cable. After getting it all put in and hooked up I went through the paces yet again, same as above. About half way, get hella stiff. This time I didn't let it break the clip.
I was thinking, due to the "new geometry" and angle, It needed a little slack. SO, I pushed in the "D" button and moved the sleeve about 70-75% OUT towards the throttle linkage. Tried again and I was able to get to WOT and maintain a "guitar string" type tension.
per this web site linked to me :
http://www.cpttransmission.com/tech_tvcable.htm
"4. Check the TV cable to insure that it is the right part for the vehicle. If you do not hear at least one "click" from the TV cable during the adjustment procedure, it may be the wrong part. "
I DID hear what I think was two rapid clicks, possibly just one.
I do not think it's anything do due with the plunger linkage connected to the valve at the tranny. When replacing the cable, I was easily able to pull that (plunger linkage) out feeling the TV Plunger operate and it spring back.
I want to test drive and see how it shifts and if not within specs perhaps snug it up a bit more. If y'all agree.
This is probably a loaded question but... Any opinions??
