Just a suburban doing suburban things.
David
David
Makes a nice sound in the meantime.You mean this little guy
Don't worry about that little guy.
I hope to redo the exhaust from manifolds to tailpipe sometime, but that isn't cheap how I wanna do it. So it will wait
So went to start the burb. And it made some noise but never cranked the engine.
Key to on, nothing comes on. Key to accessory and it works as it should.
Leads me to believe it's the ignition switch on the column.
All wires in good shape from battery to starter.
You talking about the one on top of the coulmn under the dash?
Had same problem on my dump truck this summer. It wasn't that, it was a fusible link wire on the firewall.
It could be that on yours though.
Second the fusible links... easy check before you pull the column apart.Had same problem on my dump truck this summer. It wasn't that, it was a fusible link wire on the firewall.
Depends on what blew. Had it go both waysI don't think I have ever had a fuse able link die. Wouldn't I lose all power?
Depends which one goesI don't think I have ever had a fuse able link die. Wouldn't I lose all power?
