B
Basically the only real changes were adding an electric inline pump, directly after the selector valve, along with the supplied pre and post inline filters. My return side was rerouted down the back of the engine and bell housing and over to the frame from there. And thinking about that, it means that the factory hard line on the frame is now pressurized from the electric pump, where the stock mechanical pump would siphon from that hard line in the past.
Thinking that with the decent AFR's of the Fitech, it is likely that my EGT'S are slightly higher than the pig rich carb. I'm also using manifolds and a y-pipe from a 90 TBI burb, they may be different enough from my old headers and from the non-TBI exhaust that maybe the combination heats up that hard line as it sneaks by the shackle mount on the passenger front. Factory TBI trucks route the fuel lines up the bell to the back of the engine, not along the passenger front frame like the carb trucks.
Flex line right around the area of the bellhousing.
They did this into the 400s.. I would assume your diesel thingie is the same. Look at that.
I basically kept the factory TBI fuel line routing. The braided lines run from the Sniper down the back of the motor to the hardlines on the frame rail which is about where the front of the transmission pan is but over on the frame rail. I ran the exhaust down the driver side crossing over under the bellhousing. The only place it's close is at the back of the motor. The braided lines are about 6" from the back of the headers. So far hasn't caused any problems but I've debated about putting some heat shield around them in that one spot just to be safe.
Thems some crustyI'm running the lines for the TBI in my 78 the exact way they were on the 89 burb. I actually just took this picture before cutting the ends off the lines if anyone is curious where they run.
Thems some crusty
