The 2nd pic looks good to me. The 1st makes me wonder how hot the floor will get. Maybe it's just the perspective of the picture.
I stuck some of this stuff on the cab above the exhaust. Kinda spendy if I remember but it works well. It’s heavy duty aluminum bonded to some type of insulation looks like fiberglass then a peel and stick stuff. Need to clean sheet metal or is won’t stick well.
If you remember a number or where you got that, that would be cool
That's the stuff that @mrk5 told us about which he put under the cab on his crew. I put it on the bottom of my '90 trans tunnel.
Looks good Mark. That is my favorite way to route the tailpipe(s). Once I started doing them like that I stopped breaking my exhaust off road. :waytogo:
I run some of that stick on heat shield under the drivers side floor of my cab. Made a BIG difference.
Exhaust looks good
Came out nice Mark, I'll have to spend some time and reroute mine that way I hate how it's under my cmember. Time is the key here
Maybe 8 total hours on just the side. Getting the header on and off for each fitment and working my way over the clocked t case was most of that
I suspect I can do the drivers side in half that
Yea one sides always harder. I figure with the bends I already have I can cut and index most of it but I'm definitely adding V bands! :waytogo:
Just make sure when you weld those, assemble the set and tighten the clamp so it doesn’t warp
Then mark it with a blue sharpie so it’s indexed just in case
Been on the lookout for blue sharpie markers loli probably will tig it on the k5 there's just too much footage on the cc
