Took some practice hacks last night
Took some more practice hacks again today
I have some bad habits. Sorted a few of those. Got the buzzard close enough I think I can do exhaust without ruining the headers when I attempt the V band
I did cut into the pipe and weld gaps back up.
Then I cut the pipe apart. On those, the sections I did with the “tack tack” method looked better both inside and outside the pipe. The was also true if the butt seem sections. The overlap sections looked better with the constant bead
Passenger side, marked at the offensive location
I keep trying different methods, but the tack-tack just comes out the best for me on the exhaust. Haven't had leaks or cracks or failure so I figure it works just fine.
Same here
I found HOT tacks (overlapping) worked best for me when welding the butt joints on the exhaust. Otherwise penetration was weak.
Cutting the test pipe open was fun. That hot tack, although slow, will probably be heavily utilized.
Yeah thats how I do it for as long as I can without blowing holes through.
Never TIGED, I have done a ton of welding with blue flame. I have 2 mig , 1 stick, blue flame and no tig.
