Got the passenger tank wired and plumbed direct, the driver side plumbing is done. Just need switch power wired up and that debacle is over.
Also tied up the ARB line up to the frame. Left about 6 loops of the line at the pump just to piss off Dave. @6872xtc
Thanks. Haven't had much time the last month to make progress. Tomorrow i go junkyarding to look for and Excursion rear window. Not amused.
I'm likely heading out to some yards in the AM. I'll keep a look out for an Excursion.
Sweet, thanks. I'll have my phone. I'm starting on the West side at 66th & Broadway
It's the rear hatch window for a 2005, privacy tint and heated.
Planning on using the glass on my hatch, so don't care what color the frame is.
Successful day at the junkyard, got the excursion glass and a tint/antenna replacement front for the bent77
Met @Justin V and watched him roll in mud to pull parts. Good times
Disassembled the hatch on the excursion, x2, to swap out and reseal the donor glass. The donor was an aftermarket sheet that had been sealed in with Superfockingfantasticcankissmyassadhesive. Had to carefully extract it with the sawzall.
Used more Superfockingfantasticcankissmyassadhesive @$28 a tube to glue it back in. PITA
Been out there several times when others got tickets. Come to think I believe those also were UHP
Broken windows and no mud flaps
