What rear kind of rear shaft are you running and will it handle the new steeper angle?
I'd be worried about a 1-piece shaft getting damaged on the rocks.
Glad you are already able to start working in your new garage. Doesn't seem like it was that long ago you were packing and painting.
Thanks
Looking around 56" shaft length once it's built. Actually thinking that's too short for a 2 piece. I have chunks of crap, I might build a non-cv one piece
So in theory you can just shorten the section closest to the cases right?
It would make it about 12" joint to joint, with o pretty good angle between the 2 shafts
Definitely going back to a one piece.
I saw your 56" comment after I posted. That's pretty close to what I was running before I had it shortened last week.
