B
Bent77
Guest
Back in, new gaskets. Also pulled and resealed the inspection plates, cuz MAW and WTF
You are correct. Main bearingI see a leak
It's at the bottom of the list at the moment. Probably power wash it and spray it after the leak is goneGonna have to pull that back off and paint it..
It was a steel top. Somehow I got the shift top hung up on itself. Pulled it of, rinse, repeat. Put the original on and it's happyWas it the aluminum top one that was a problem?
went out the window fast. Now it works
Ok hippie. Enjoy your 50th HS reunionYou need @Babaganoosh to help you with your tranny issues.. ..
Since your manny tranny is seeping...
from the ...........
And you gave him so much grief.......
And you can skip the hippie comments this time...
Yeah found another small leak on the 203 as well. Kinda pissing me off. I'll let it pee for a weekOil leaks suck on stuff you have already "fixed".
