Every now and then one has to remind you where you started from.
Either way, have the output shaft stripped and the reusable parts set aside for a rainy day. Next I'll do the same to the 10 spline and make a decent 32 spline out of the best parts.
Trying to come up with something ingenious to do with the spare 465 case...
15 minutes after we talked earlier, the pump that I am running suffered main hydraulic pump failure...
There are two hydraulic pumps, one runs the concrete pump, augers, water tank pump. This is the main pump. The secondary pump runs the boom and outriggers.
I know it isn't your fault. I'm just picking on you because you are the last guy I talked to before ka-put...
@mrk5
Ordered a throw out bearing today AKA clutch release bearing.
Prices as follows
$25 Chinese junk like the one I just pulled
$38 National Bearing brand
$50 HD unit form NAPA.
