B
Bent77
Guest
TBI wasn’t getting it done and I protested investing more on the TBIWasn't this thing supposed to be injected? Or did I miss something?
How would you know that you had a sniper system?Sniper would be nice
I would guess long range air deliveryHow would you know that you had a sniper system?
Would it sneak in, and of a sudden strike?
Or pop out from under something?
My Dad always told me to leave it alone... He came home one day the air horn was off and everything was laid out... It was my daily driver.That’s actually the first thing I ever learned to work on. Dad had a Qjet sitting on the shelf in the garage
He said I was about 6 when I took it apart and somehow got it back together
Ruined for life
Took me a few tries because of the double metering rod hangars to get the top back on but still a trip how well they run on a range of motors..That’s actually the first thing I ever learned to work on. Dad had a Qjet sitting on the shelf in the garage
Ruined for life
Ferrule as in they wouldn't fit the diameter of the sender tubes?Ordered a new bearing for the back of the 205
Also not had good luck converting the sender to the ferrule style AN fittings. Hoping to back up a bit and maybe use these
