That’s for the gas thieves
Drive it to the station, no issues. Put 20 fresh 91 octanes in it, and readjusted the idle screw to reset the IAC at 5
No funky tape and hold your tongue to one side to set it
Drove it easy down the county road to get a feel for it. Needs a light return spring, throttle is pretty light and easy. Too easy.
Little lazy but not bad. Smooth, no weird spots in the RPM range. Gave it some throttle going up the county road. Could already feel some adjusting had occurred. Ran it up to the state highway and pulled off. Checked for leaks.
Return loop, just more putt putt back to the stop sign and turned. All primary throttle, up to 5k clean, paddled a few gears and ran it up to 75. Barked out the exhaust on the 1-2, but that was it in terms of issues on the drive
Hammered it off the light, pulled to 6k, cleaner and more firm than the first pull. Downshifted it hard from 3-2 up to 5500, no issues
All this on the base setting. I made no changes other than setting the timing and aforementioned idle screw
Way easier to set up and use than the Holley. Already runs and idles clean. I’ll be curious to see if/how it improves with more miles, at 20 right now
