She's officially long travel!
No limit straps and stock driveshaft means VERY mild driving while I wait for my driveshafts (probably 3 WEEKS, AGH) and limit straps. I'll cut the U bolts down when I go in to set up the limit straps.
The stock driveshaft is locked up for the last 3-4" of travel. Been talking to Dynamic Drivelines, we're gonna run 1350 U-joints up front and 1410 in the rear for the extra angle. I'm having a 10 bolt 1410 yoke turned down for the 12 bolt seal diameter since they don't make a 1410 12 bolt yoke.
Gave the driveshaft guy measurements Tuesday. I didn't get the invoice yesterday when I was supposed to, spoke to them this morning and was promised it by EOD today. After EOD, still don't have it and no call from them. Hopefully this is an anomaly and they don't do business like this, if you give me a deadline I expect it by that date, or clear communication if delays occur. Tomorrow is day 3 of waiting for the invoice, if I don't get it I will cancel the order and order from somewhere else. If it takes that long to send me an email, I doubt I'll see my driveshafts in under a month and I will not wait that long.
You can see in the above photos that I don't have the rear plate welded onto the trac-bar axle mounts. The brackets sat at the same exact width of the U bolts, so I couldn't put them between the U bolts. I had to offset them, and if I weld the rear plate on I will not be able to install/remove the inner U bolt. I was gonna notch the corner to allow it to slip in and rotate up, but then it would pinch the brake line, and there's nowhere to move it without getting new lines and re-routing. Kinda surprised to see this from an ORD kit, there's no way I'm the only guy who ran into this problem.
Drove fine around the block, taking it for a test drive to the gym in ~30min. Happy to FINALLY be (mostly) done with this build, this is gonna be the sweetest truck around
