The Jimmy build, beat and rebuild with very few updates.
Oh no.. the end is near. We shoulda seen this coming when you moved away from the Dezert.. at least your crawler will be comfortable..
This will be different.
What's your timetable?
I will say this, as a n00b going down the dragon's tail, or whale's tale, or whatever that really scary downhill on Hell's is called, as I peaked over my blue hood, the first thing I saw was Wade at the bottom helping guide folks down. Probably the most welcome sight I had all weekend. lol.
Front passenger caliper? I seem to recall you deciding that one was overrated after breaking that line...umm...3??? times in Michigan. :haha:
Just bought fron and rear tons, Detroits, discs, 5.13:1. All new internals. So it has started. Just have to save funds for the Magnum box. And everything else.
Care to share the plan? Or is that going to your grave with you? :thinking:
The plan is, I have 2 axles. I will use them to hold whatever I build, up.
And I only broke the fitting twice. Blew up the battery in the camper once and broke a hydro fitting once.
But I go to Moab and wheel for four solid days and only have the caliper pin break.
Time for a new ride.
So if you plan a magnum box you must plan on going slow? I understand the "with age comes a cage" deal, makes sense. But if you have a cage, why go so slow? :wink1:
