andyblack
Registered Loser
Looks like she can spray paint pretty good though. No visible runs or drips or anything.
Whatta pain she is....
Looks like she can spray paint pretty good though. No visible runs or drips or anything.![]()
Saturday Night 12 AM we went out for the Annual midnight run, July 1st is the first day the flats are open, no photos from that cuz it was too dark. We were the biggest rig in the group of 30+ Jeeps in stock trim
so we didn't play too hard. Had a few 3' deep water crossings and had no issue, didn't hardly even get dirty. We mostly camped and hung out. We had a dip**** in a Ranger destroy a wheel bearing next to our camp at 3AM that same morning. The wheel popped off and passed him.
They took an hour just to get it out of the road.
Thanks man!!This truck is so sick...![]()
FINALLY!!!!
And wtf, you have a semi??![]()
Ass![]()
Please don't hack the fenders too much!
Have any more pics of your winch mount? Trying to see where the drum engagement lever lands when you mount feet forward between the frame rails.
Thanks.
Sweet, Haha I know what you mean!! I took mine out about 2 weeks ago for a little flex/trail ride to see how I liked the new tire/axle swap, and those ground hawgs chewed the driver side fender to hell! Probably gonna end up doing the same cutting your doing.
I'm assuming your tranny cooler is the one in the bed in your pictures? If so, what size cooler and cfm fan do you have on it, and what temp are you running about? That's next on my list.
Ill get some more. I centered the fairhead and used the bottom pad bolts to hold on the fairhead. My lever ended up on the drivers side with ample clearance from the frame. frame. Since I have a 2" bodylift its pretty easy to engage/disengage. My control box is mounted between the rails as well and is easy enough to reach from the passenger side. I didn't cut the grill or the grill trim piece eithet
truck looks BAD
